- Jan 1, 2023
- 4,296
- 9,087
I didn’t know column mounted electronic gear selectors, not cable or linkage operated, have been around for 8 decades. Learn something new everyday. But this new feature definitely makes it easier for the govt to throw and lock your truck in park if you’re being naughty.This "new feature" was standard equipment on trucks for 8 decades until some homo on the Covid design team decided to put a console shift in and buttons on the dash of the Tahoe.
You didn't know because they haven't. It was all linkage. The point is the column shifter and not the way it shifts.I didn’t know column mounted electronic gear selectors, not cable or linkage operated, have been around for 8 decades.
The sarcasm went right over your head.You didn't know because they haven't. It was all linkage. The point is the column shifter and not the way it shifts.
I worked at a beer distributor in the early 90s.This "new feature" was standard equipment on trucks for 8 decades until some homo on the Covid design team decided to put a console shift in and buttons on the dash of the Tahoe.
Unfortunately, there are a lot of stupid people on forums so I take nothing for grantedThe sarcasm went right over your head.
Yep, that's when you started to see it with heavy equipment as well. Excavators were early adopters of drive by wire moving away from direct linkage and hydraulics to the controls.I worked at a beer distributor in the early 90s.
All of the International DT466 engines were paired with Allison autos.
Touch pad shifters.
They also displayed the fluid levels.
