CZmenghe is a Supporting Vendor!
Hi everyone!
Thanks to ChevyZR2.com for the warm welcome and introducing us to this amazing community! We’re excited to join as a supporting vendor and connect with fellow ZR2 truck enthusiasts.
CZmenghe specializes in creating plug-and-play, user-friendly upgrades for trucks like the ZR2, built around three key focuses:
✅Strong Compatibility - Designed according to the ZR2 Original Vehicle
✅ Easy Installation – No complicated tools or expertise needed.
✅ Function & Style – Enhancements that boost both utility and aesthetics.
Whether you want to boost off-road capability, upgrade the look, or maximize practicality, we offer ready-to-use solutions. From bed divider and dashboard storage organizer to retractable ratchet straps and storage systems, every product is meticulously crafted for seamless fitment without compromising quality.
👉 Shop Now on Amazon to explore our full range and enjoy exclusive deals!
Questions? Need advice?
Email us or DM @CZmenghe
Let’s turn your ZR2 into your dream rig together!
👋 Hey everyone, meet the CZmenghe Team!
We’re a new force in the ZR2 world, here to bridge the gap between late-night forum sketches and everyday DIYers . Ever had a brilliant mod idea shelved because it required a CNC machine or an engineering degree? We’ve been there too.
What We Do
  • Weaponizing Ideas : Taking your garage epiphanies and turning them into plug-and-play kits —no fabrication skills needed.
  • Production-Grade Quality : From TPE to carbon steel, we harden your concepts into durable, ready-to-install solutions .
  • Community-Driven Design : Your feedback shapes our roadmap. If you’ve abandoned a mod due to complexity—maybe we could help you!
Our Commitment to You
  • Dedicated Forum Support : A team member will answer your pre-sale/post-sale questions directly in this forum—response within 24 hours .
  • Worry-Free Warranty : 30-day returns + lifetime technical support.
  • Transparency : We’re total newbies—our stuff isn’t perfect yet. But we’re all ears for constructive criticism. Seriously, hit us with it!
Why We’re Here
We joined this community to create value for fellow modders.
Our goal? To bring convenience, joy, or even a little surprise to your Silverado Sierra.
  • Not satisfied? Let us know—we’ll fix it.
  • See our progress? Drop a thumbs-up—we’re grateful for every one!
We might not be flawless, but we’re obsessed with getting better. Together, let’s build something badass.
📦 First batch drops soon—stay tuned! Let’s kick things off with car storage and decor accessories!
We need a set of fender flares designed specifically for the Silverado 1500 ZR2. The 1500 ZR2 has a unique bumper and front fender and NOBODY has a set of fender flares for our trucks. Only have normal Silverado 1500 fender flares that need modifications to fit our ZR2'S. Another vendor designed a good set but the shipping to the United States was higher than the cost of the product.
Can you design a set of bolt on fender flares specifically for the 22-25 Silverado 1500 ZR2 and reasonably ship them to the United States? Preferably the Riveted Style Fender Flares, if possible.
We currently don’t offer fender flares, but a combination of two other products might help address your need. One is a rear tire liner for ZR2, and the other is a mud flap for ZR2. Please feel free to check them out!
Reactions: KLA
Interested in these two products? 👍 Like this post! If you hit 5 likes, I’ll apply for a discount coupon."
View attachment 23514View attachment 23515
Nobody has fender flares for the 1500 ZR2. Was hoping someone could design them.
Do you have any pictures of the fender flares you're looking for? I will forward them to our technical team
Per your DM question I took some quick measurements of the 1500 and 2500HD grill opening. I cannot load pictures in that DM, so will post it here.
As I mentioned, the openings are much different on each grill with the 2500HD being larger. I dont think the lights are compatible between the trucks and also, the marker lights would be too large in the HD truck if the same design was used to fill the opening. You would need a larger non lit bezel to keep the size of the light down. These aren't functional lights, just accent lights or marker lights.
You're totally right—the grille light's more about style than function, so looks are the main goal.
Quick update: The 1500 size you mentioned works great—we’ve double-checked and it’s good to go! 💡
But for the 2500HD? The pic’s a bit fuzzy on the exact measurements. Might need a real-world install test to be sure. 😃
It's 1/4 inch wider and 5/8 inch taller. Also the back is tapered, so its different in the rear. I assume that is your limiting factor since that's the where your attachment point is located.
I think you need a CAD file of the grill design or order a grill for measuring/test fitting. Me sticking in a 1500 light kit will only tell you it doesn't fit and I already told you that.
