Dual Map sensor Spacer
When you change your oil, remove the 10mm bolt, unplug it and take it out. Clean it, put it back in. It just isn't really that hard to do.
Has anyone used the Banks Map Sensor spacer kit and is it worth doing it?
Thanks
I bought one. Used it for about 3-4 months and took it out and threw it in the trash. Better to just remove the sensor every oil change (3-5K miles) and spray it with MAF cleaner and reinstall it.
I agree with others. I have one sitting on the bench. I swap it during the oil change and clean while consuming beer/scotch and doing other man stuff in the garage.
