- Feb 21, 2023
- 6,882
- 16,562
I decided to change the gear case and transfer case fluid on my ZR2 and wife's Tahoe. They are both coming up on 3 years of service but ZR2 only has 17k miles and Tahoe 25k, so not a lot.
The transfer case and rear differential fluid on the ZR2 looked more used than the Tahoe, probably cause I like to rip it and offroad it a bit. The transfer case fluid was OK, but it was starting to change color to a darker maroon color so I am glad I changed it. The differential fluid still looked decent, but the magnet was pretty full. The front differential was pretty clean and probably didn't need to be changed.
The real PIA, is there are no drain plugs on the ZR2, so you have to pull the whole covers off to drain them.
They have so much red thread locker on the rear bolts, that I could barely get them loose without rounding the shitty soft tiny 10 mm bolt heads. Ended up using a nut extractor on one of them.
The front differential didn't appear to have red thread locker, but they were hard to get out too. Also hard to reach the upper bolts cause the wires for the electric power steering rack are in the way.
I thought it was gonna take a couple hours for both, but with those covers it took about 4 hours. The transfer case was easy, but you have to pull skids for that and the front differential. The Tahoe was significantly easier with the drain bolts and easier access.
