Diesel328
- May 21, 2022
- 184
- 327
"According to GM Authority sources, the 2023 Chevy Silverado ZR2 will be built in very low numbers, with just 5 percent of the original 2023 Silverado ZR2 unit total set to be produced."Not really. If they build 500k Silverados, that's still 25k ZR2s. Not rare at all.
You are exactly right! Hence the title of the thread."According to GM Authority sources, the 2023 Chevy Silverado ZR2 will be built in very low numbers, with just 5 percent of the original 2023 Silverado ZR2 unit total set to be produced."
Based on this, it doesn't sound like it's 5% of the Silverados made, but 5% of whatever their projected ZR2 numbers would have been, but I could be wrong...
Yeah that's not correct. It's 5% of available allocations will be ZR2."According to GM Authority sources, the 2023 Chevy Silverado ZR2 will be built in very low numbers, with just 5 percent of the original 2023 Silverado ZR2 unit total set to be produced."
Nice! What color did you go with?I went ahead a pulled the trigger on an order today just because of that article. Dealer had two allocations and zero markup. Said there were no constraints currently but consider me skeptical there. I guess we’ll see.
Summit whiteNice! What color did you go with?
