Quite the conundrum..
I have had an interesting series of events that are throwing me for a loop, I’m going to lay them out in tandem with my thought process to see if anyone can lend me a hand.
I traded in my Colorado ZR2 for a Silverado 1500 ZR2. Knowing it was used, I 100% expected to into things that needed to be fixed since the previous owner evidently treated the truck horribly. After a couple things that had to be rectified like the strut top hat being blown through (i have videos of how i was driving it, pretty scary stuff), I moved on to the current issue; being annoying rear end sounds. Im no stranger to GM rear ends being low quality but in my head it was going to be a simple fix with proper lubricants for metal on metal contact with the leaf springs and the bushings in the shackles (given it was just minor creaking from dry components), etc… let me tell you, i was wrong. I am currently learning the meaning of “every 30 minute job is one broken bolt from a 3 day ordeal”.
What I'm dealing with now that has me puckering every time I’m driving:
- full blown clunking every time rear axle flexes (was not present before lubricants were applied)
- small chirps at low speeds with tiny bumps
- a clunk can be felt in the steering wheel, cant tell if its just the vibration from the rear end noises or if i have a ball joint/tie rod issue that joined the fight.
- steering is stiffer turning right, and easier turning left (maybe sway bar end links?)
Now my thought process is that given this truck wasn't taken care of very well before me, my intent is to torque everything to spec, and double check front ends joint grease, and if that doesn’t do the trick replace anything that could be worn out, i.e. shackle bushings, upper/lower ball joints, inner/outer tie rods, possibly the lead springs entirely with something from peak suspension.
That leads me to my next problem, I can’t fond anything online for OEM or better quality parts that definitively say they are for a 2023 Silverado 1500 ZR2.
Did you buy it from the YTubber that was ramping it?
Parts are hard to find for these trucks. I've been looking for white front fenders and nothing out there yet.
I dont want to purchase new and have them painted.
For the leafs-
I recommend getting replacement u bolts. Apparently there's history of them being loose from factory.
You could try tightening them, but it could persist.
Apparently the tank filler pipe sometimes leaks on the leaf causing the plastic separator pads to degrade and squeak/ clunk.
If you want to get rid of it definitively and get a better ride just install deavers lol.
Can't speak for the clunk- could be 50 different things.
As for the steering being stiffer to the left- have you gotten an alignment? Other than failing power steering- which is unlikely- that's probably the most likely issue.
I got it from a dealer that got it from an auction. The fax were clean was really I was looking for.
For the leafs-
Ill take a look into those few things today, as far as the alignment goes, I had gotten 2 alignments in the last couple months cause the mud terrains it came with were defective and had it dancing down the highway. But I wouldn’t be surprised if the quality of the alignment is the issue because the first one they did had the truck going straight with the steering wheel at a quarter turn.
GM trucks had a history of having a steering wheel clunk. It is due to the intermediate steering shaft play and lack of lubrication. Haven't heard of it much in recent years, but is something to look into.
There are posts regarding rear end noise and you may find your solution there. Everthing from lubing, retorquing, new springs, new axles.
As for the front, you should be able to get aftermarket parts from the various performance suspension shops. Might want to bring it to a local lift shop for diagnostic work.
It may be worth trading it and not chasing all the issues.
Purchase an extended warranty from one of the Dealers that have been mentioned for great pricing. They offer no interest payments and you get a true GM warranty with GM replacement parts. On these trucks you will be glad you did, peace of mind. Knapp and James Black Cadillac are two that come to mind and there may be more. Good luck with your current situation.
