the forum isnt allowing anymore Glacier Blue ZR2's.....we have reached the limit. i would suggest North Sky Blue if its 22 or 23.About to be a new ZR2 owner and I need to see some Slate Gray builds. I’m undecided between GB,SW, and SG.
brilliant!!Here you go.
The sun was setting behind the mountains so the picture came out a bit wanky.
I had just installed my black ZR2 emblems this day.
Wow, hands down slate gray is the way to go. Thank god for this pic as I was leaning towards the white.
www.courtesychev.com
You getting any rubbing on the UCAs with those Toyo AT3s? I test fit some 37 Toyo MTs and there was only about 1/8 inch of clearance. Figured it would rub offroad.Few color matched bits, black emblems,37s, amp steps, baja designs s8 behind grill and xl80s on a pillar
wow...those tires fill out the wheel well. great job.Few color matched bits, black emblems,37s, amp steps, baja designs s8 behind grill and xl80s on a pillar
No rubbing. Even with a Fisher XV2 plow hanging off the front.You getting any rubbing on the UCAs with those Toyo AT3s? I test fit some 37 Toyo MTs and there was only about 1/8 inch of clearance. Figured it would rub offroad.
What width are the tires? I've tried 13.5 but I wanted more width for wider stance.No rubbing. Even with a Fisher XV2 plow hanging off the front.
why not just order the truck in Primer? Then you can have it painted any color you want by someone that knows what they are doing with the spray can,Wow, hands down slate gray is the way to go. Thank god for this pic as I was leaning towards the white.
You say that, but I had a 74 Custom Deluxe Chevy. I primered the whole truck gray. I didn't have the cash to paint it then, so I just drove it with the primer. These slate gray trucks actually remind me a lot of that truck. It was basically the same color, it just didn't have the glossy clear coat. First thing I thought of when I seen the new color was chevy done went and clear coated primer, lolwhy not just order the truck in Primer? Then you can have it painted any color you want by someone that knows what they are doing with the spray can,
nothing wrong with a nice hotrod in primer.You say that, but I had a 74 Custom Deluxe Chevy. I primered the whole truck gray. I didn't have the cash to paint it then, so I just drove it with the primer. These slate gray trucks actually remind me a lot of that truck. It was basically the same color, it just didn't have the glossy clear coat. First thing I thought of when I seen the new color was chevy done went and clear coated primer, lol
rig looks good. welcome! you can get a black emblem kit from chevy accessories.Love the Slate Gray color! Picked up this one two weeks back. Deleted all the chrome off of it and definitely stands out.
View attachment 9915View attachment 9916View attachment 9917
