- Jan 1, 2023
- 3,850
- 8,195
Just what we've all been asking for...
The sound it makes while adjusting the ride height will mute several times within the first 5 minutesUsing processor sensors and controllers,
What could go wrong?
Yep...just step on the gas and all of that water just drains right out!Sounds like a complicated solution to a very simple problem.
Yep, that’s what engineers do.Sounds like a complicated solution to a very simple problem.
Not all of usYep, that’s what engineers do.
Enter "RANGE DA Module"If GM puts this into practice, we are all doomed or we find a way to disable it.
@securityguy you know I wasn’t referring to you. I’m referring to the ones that don’t know which end of a screwdriver to use.Not all of usI have always taken pride, when designing things, to take into account who may need to fix it if it breaks. Too many engineers don't think ahead and only try to solve a problem without thinking after the fact. To add sensors and actuators to a truck to rid itself of water in the bed is more like a patent issue only to have it on the books versus true implementation. If GM puts this into practice, we are all doomed or we find a way to disable it.
100% my friend. Just adding my 2 cents...nothing more.@securityguy you know I wasn’t referring to you. I’m referring to the ones that don’t know which end of a screwdriver to use.
