Vibration Even when in Park
ZR2
I noticed my car vibrates at low speeds and also high speeds and unfortunately when its stopped at park i can see my phone shaking while on the BulletPoint mount. What could be the issue? Engine or trans mounts? Gotta check the exhaust if its rubbing.
Yeah, mounts or something else loose like the alternator/fan belt/bearings.
Could also be your transmission acting up. There's plenty of transmission issues showing up on these trucks, so may need to have the dealer look at it.
Also, you could be losing the crank or rod bearings too. May be a motor starting to go bad.
