2024 ZR2 purchased a month ago
Nov 4, 2024
9
16
Greetings everyone. This is my 1st pickup which I like much so far.
What has been done:
- matte film
- bed cover (BakFlip MX4)
- tinting
- dashcam (overheats)
- bike rack in bed
- bent skidplates after dune driving
Main question I have so far:
- how do i change units (pressure/fuel consumption). There is no units in any menu and dealership does not know too.
Check the infotainment system menu. It may be in there versus the DIC.
I have gone through each item of DIC and as well as through the main screen maybe hundred times. Tried every element. There is nothing that allows me to change any unit in this car. 2023 Manual refers to Units is Settings menu. There is no such item in my car. Manual that was with the car does not have that element of the menu, however it is worded in a way that diferent units are possibel (e.g., it says that consumption may be in mpg or km/l or l/100km.
Only the white ones show the correct units
I wish it was true. My colleague has white 2022 and same issue with units (although i did not check all his menus as thoroughly as mine). If you have that setting can you show where it is?
Another question: I have dune flag for quick release mount. What would be the best and easist place to install the mount? Ideally without damaging the truck. Appreciate all thoughts.
Hello,
Recent new owner of a ZR2, I am as well experiencing the same issue : no way to find the setting menu and thus change units.
I am in Qatar and in view of your location, I am starting to wonder if it is not linked to some "location" constraints.
For instance, I have as well notice that there Google Built-in features in my Silverado.
Did you manage to solve your issue ? If yes, please share ;)
Thanks
Hello,
Thanks
hi. i have not found the solution. i have visited dealershiup and they do not know too. i plan to go to service and ask them
The units function is changed in your instrument cluster under "Options". See 113 in your owners manual
I have gone through manual 10 times - both printed one and online. Online refers to Units submenu which i do not have. Printed does not shopw any way to change this.
Update re DIC and changing units. I mentioned earlier that this option is absent from the DIC settings. I have visited the service workshop (because dealership could not help and suggested their workshop). According to the workshop, there is no way to change it. They said that GCC specs have this specific units (km/L, kPa, C*) and they cannot be changed. They said it is not possible to code it, or use special equipment to change. They are aware of this issue but no solution has been provided by GM. This is what i got. Disappointing but i am thinking to ask more around. If you guys could also ask your dealers/workshops if there is a coding option this could help me talking here a lot.
CHeers
my own response - i used a mount bracked from Ali that connects to the side panel of the tailgate.
