🛠️ Member Build 24 2500 Bison Diode Dynamics Ditch Light, SPod BantamX light controller, SDHQ pillar mount brackets.
2024 Chevrolet 2500 Bison ditch/ pillar install complete. I used SDHQ mounting brackets and the awesome SPod BantamX with touchscreen controller, with strobe/flash/dim. This helped to make the install pretty clean.
  • IMG_8284.mov
    3.5 MB
Do you have any photos of where you ran the wires through the firewall? Looks great BTW!
Thanks love my set up. My installer used the attached service bulletin from GM to route the wires into the firewall. You have to cut into the rubber plenum in a small window on both the driver and passenger sides. Beware the small window won’t accommodate a lot of wires.
Good luck!
How do you like the BantamX so far? I'm torn between that and the Switchpros sp9100 right now.
