2500 Running Boards on 1500
Okie.ZR2
Quick google search was inconclusive…do boards from a 2500 fit on a 1500?
Found some cheap high clearance steps on FB and considering swapping the sport steps. Thanks!
Power retracting? Cause the wiring the computer into the BCM might be the issue.
The cabs are identical, but can't say for sure if the mounts into the cab frame will be the same.
Thanks @AXE. The ones I found are the stationary GM high clearance steps from a 2023 2500 AT4. $175 for them…seemed like a slick deal!
EDITED TO ADD- same part numbers on GM website for 2500/1500 so I’m going to buy them and hope for the best!
