2500HD AEV Bison Wheel Specs
I contacted AEV to get the specs on the Bison wheels. I suspect it's probably the same for the standard HD. Pretty large + offset, I was thinking less.
Here's what they said:
"Those wheels are 18x9” with a 32mm offset, that comes out to approximately 5.75” of back spacing."
I'm debating about getting some different wheels to run 37s, so want more clearance between UCAs. Maybe 18x9.5 12 or 6 mm offset on these Rhino wheels.
Im wanting new wheels also. I like the factory rim but it is a PITA to clean.
Im seeing a lot of +18mm offset which would push the wheel out towards the fender (ASSUMING the stock wheel is +32mm like the Bison mentioned above) about a half inch would might be perfect.
I don't want them poking out too far.
+12 to +18 is perfect for running 37s and will give clearance for 13.5 wide tires, (along with the AEV clearance kit) I have +12 methods and they are just about flush with the flares
Post some pics of that beauty
check my thread
