A Reliable Way to Protect the Door Sills of Your Truck
powoq
🌟 Forum Vendor
Hey everyone,
With frequent stepping in and out, the door sills easily get scuffed over time. Plus, when you add rain or mud into the mix, that bare metal step becomes noticeably slippery.
If you are looking to prevent these issues, our TPE Inner & Outer Door Sill Protectors provide a solid solution.
How our TPE protectors work:
By using thick, flexible TPE, the material absorbs daily friction and impacts, protecting the factory surface underneath. It handles temperature changes well, staying durable without fading or cracking over time. Compared to the bare metal step, the molded textured pattern provides a much better grip on wet or muddy days.
Why not choose universal Polyvinyl (PVC) decals?
While vinyl stickers might look okay at first, they offer minimal impact protection. If there’s an impact on the sill, the surface underneath can still take the hit. Plus, flat vinyl tends to be slippery when wet, and the edges often start peeling and trapping dirt after regular use.
Our TPE protectors are tailored for the 2019-2026 Chevy Silverado and GMC Sierra 1500 (Crew Cab models only). They install cleanly with pre-applied double-sided tape.
🔗 Available here: You can enjoy a 10% discount with code POWOQ10 for your first order!
