Oil choice is kinda like underwear choice...very personal, and everyone else's is wrong. That being said, there was a time in my past that I lost two very good race engines to Amsoil, and after the second loss, switched out of that and the problem appeared to solve itself. I never used it again. Since they mentioned oxidation, Mobil-1 had problems in aircraft engines because it couldn't displace the lead in the fuel, which was causing corrosion of camshafts in both Continental and Lycoming engines, in addition to lead sludge, so Mobile withdrew that oil from production and no longer recommends using it. Subsequent testing indicated that Mobil-1 performed poorly in protecting engines from corrosion, when infrequently operated.“Ugliness showed up with the AMSOIL”
wait... people wear underwear????!?!?!?!Oil choice is kinda like underwear choice...very personal, and everyone else's is wrong. That being said, there was a time in my past that I lost two very good race engines to Amsoil, and after the second loss, switched out of that and the problem appeared to solve itself. I never used it again. Since they mentioned oxidation, Mobil-1 had problems in aircraft engines because it couldn't displace the lead in the fuel, which was causing corrosion of camshafts in both Continental and Lycoming engines, in addition to lead sludge, so Mobile withdrew that oil from production and no longer recommends using it. Subsequent testing indicated that Mobil-1 performed poorly in protecting engines from corrosion, when infrequently operated.
