Best aftermarket suspension upgrade
Hi everyone,
Looking for some guidance on what is a viable and quality upgrade from the multimatic DSSVs i currently have.
I know people mention peak suspension a lot but what is there beyond that for some options?
I already replace the leaf springs with M27 Deavers. They squeak like crazy but they are smooth. So any advice on how to stop them from being so loud would also be appreciated before i stock them back out.
Bushings might be dry, try silicone ptfe spray. Also check alignment on leafs.
Alignment on the leafs looks good, both the stack itself and how they sit on the axle.
Do i need to pull them off to get inside the bushings? Because i have put silicone grease spray all over them in the past
could just be material of the bushings themselves. How much front lift to you have? Assuming you added on top of factory lift
This is where it always gets interesting. Lemme preface this with the fact that I purchased this vehicle with a Ready loft leveling kit up front and nothing in the rear, just a factory block.
But the rear end currently has factory block plus the m27s, so +1.5 from factory in the rear to make it level
