Covered Up the Exposed Metal with powoq Rear Wheel Well Liners
powoq
🌟 Forum Vendor
Hey everyone,
If you drive a Chevy Silverado, you’ve probably noticed the rear wheel wells often leave the bare metal exposed, which can make cleanup a hassle while disrupting the truck's overall visual flow.
To help solve this, our team designed the Rear Wheel Well Liners for 2019–2026 Chevy Silverado 1500 with a 5.8ft bed.
Crafted from durable PE material, the liners cover the exposed framework to give the rear wheel bay a more integrated and finished appearance. At the same time, the smooth surface helps reduce the long-term accumulation of mud, snow, and road salt, making post-drive rinses easier. Additionally, they help dampen some of the gravel impact sounds while driving.
Installation is straightforward and uses existing factory mounting points, meaning zero drilling or modifications are required on your truck.
If you are interested in checking them out, you can find them here: https://bit.ly/c9xew
(Enjoy a 10% discount with code POWOQ10 for your first order!)
