Drop hitch
Going to get a B&W stow and tow hitch for my 2500ZR2 Searched the threads and could not find the drop size in inches to purchase. I also want to get it in 2-1;2” size so no sleeve is used
Thanks for anyone’s feed back!
The only B&W I’m seeing that’s for the Multi is the 7” drop.
I have the 7" with 37s and use it around half way on the drop with most trailers. 7" is the sweet spot. I bought the 3-ball version planning to tow everything and have yet to see a coupler under 2" haha. The third little ball does make for a clean grip to spin it around and adjust it between 2" and 2 5/16" though.
Waiting on confirmation from Bolt Lock that it will work with our keys (unless one of y'all has already done it). Are the three other Stow and Tow pins also standard 5/8" hitch pins?
I have the B&W 7" for the multiflex tailgate. Works great. No heavy weight, but have done about 5k towing out of 31K miles. I use it for my 15k dump and 8k enclosed.
You only have one option B&W TS20066BMP. 2.5" shank 7" drop. We'll technically 2 options. 2 ball or 3 ball version. I haven't seen a 1 7/8" coupler in a long time though. Good hitch. I had the 2" version on my 1500. Got the 2.5 for the HD. They only make one drop size for 2.5" shank. Max weight rating is only 14,500 and 1450 tongue weight though. I've used it to move my camper, but I wouldn't tow it with it. Does fine on lighter stuff though.
