Gotta question about offsett
Ponyboy
39
91
I'm sure this has been discussed many times but I can't find those older threads. I'm currently running 1.5-inch spacers on stock wheels and tires and like the stance and look of the truck so if I were buying some Fuel Rebels, for example, would the offset I want be -9 in order to match what I'm currently running?
I think it would be closer to 0 or -12, never seen -9 but it would be in the middle. It also depends upon if the wheel width changes from 8.5 to 9 or 9.5. Your gonna pick up 1/4 inch or more in extra width if it's a wider wheel.
You can check my thread out on my Method 18x9 -12 with 295s. It looks good and plenty of width. You will get some more rock chips on the side.
Keeping the same 8.5" rim width you would need -12 to match the 1.5" spacers.
I believe the Stock wheel is 8.5" +26mm offset or 5.77" backspace.
25.4mm=1" so 1.5"=38.1mm
+26mm-38.1mm=-12.1mm
After think about it for a bit, the -12mm offset would center the rim the same for any rim width.
8.5" rim -12mm offset would be ~4.27" backspace
9" rim -12mm offset would be ~4.52" backspace
4.52-4.27=.25 which is half of the .5" width difference
Just my .02 worth
Just my .02 worth
Thanks for the help, really appreciate it.
Just my .02 worth
you lost me at "keeping"
