Light-up “Flow Tie”??
I posted about this a while ago and a few people said there was someone out there working on a light-up Flow Tie for the ZR2s. Normal Silverados have a pig tail behind the grille to be able to install the normal light up bow tie which is a Chevrolet accessory, I would assume the ZR2 would have the same pigtail behind the grille but the issue comes with the fact I don’t want to install a solid light-up bow tie. I was just curious if anyone has come across a light-up Flow Tie option yet?
I had my grill apart putting in my grill lights, I saw no connector or cable to power the bow tie, I have not found any solution except custom making your own, I know someone that is working on one but he isn't there yet, and it looks like it will be a while.
A light up logo is cheesy to me...not a fan.
You could use a 24-in LED strip from Amazon, etc inside the hollow section just behind your bowtie. I've seen a couple and they look pretty decent and are really cheap.
I have not yet seen a lighted Flow Tie version available for the ZR2, only the classic bow tie.It would be really great for an accessorizer to do it because it would keep the original look while being bright.
