📣 CZmenghe | Taller Truck Bed Divider: Divide The Cargo Box Sections and Secure Items 📣
CZmenghe_Team_John
🌟 Forum Vendor
Hey everyone!
While the vehicle is in motion, tall cargo is prone to tipping over during sudden braking, and unsecured tools may slide around inside the cargo area, creating noise. This can cause wear and tear on the items themselves and may also scratch the bed walls of the cargo area.
The Taller Truck Bed Divider is compatible with 2019 2020 2021 2022 2023 2024 2025 2026 Silverado and Sierra 1500. It's also compatible with 2020 2021 2022 2023 2024 2025 2026 Silverado and Sierra 2500 3500. NOTE: It's NOT compatible with Sierra Carbon Pro, Denali, or AT4 models, nor truck beds equipped with a drop-in bed liner.
The design of the elevated net plate effectively prevents tall cargo from tipping over during sudden braking. The panel is designed with a composite hole pattern (X-shaped holes, long slotted channels, and multi-hole matrices), which supports the fixed of items at multiple angles, eliminating the abnormal noise caused by the rolling of items during travel. It can separate wet and dry items and make efficient use of the cargo box space.
Made of high strength light aluminum alloy, it has impact resistance and is not easy to deform. It is resistant to rust and corrosion, ensuring long-lasting durability. The springs and foam pads at both ends effectively reduce the friction between the divider and the vehicle body. Installation is simple. No drilling is required. It can be folded and stored when not in use.
🛍️ PURCHASE LINK: 🛍️
Amazon Link: CZmenghe Taller Truck Bed Divider
✨Join our community to stay updated with the latest product releases, exclusive promotion discounts and abundant opportunities for free product trials.
