New 0W-40 oil and extended warranty talk
Good video! I always thought it was a safe bet to run a higher viscosity for severe duty use. I would say in Arizona with temps around 110-115, a higher viscosity oil would be better.
Like @TexOffroader said, why the big jump though? Why not just 0W30? That still a bit of a head scratcher. To me, it just further indicates that we have bad bearings and cams and they are worn more than normal for the age of the vehicles. GM just buying some time, no real magic.
My question is: I just purchased a platinum GM extended warranty for my ZR2. If my motor passes this inspection, the 10 year/ 150,000 mile special warranty alligns right up with the extended warranty I just purchased (Besides the miles, ill hit the year cap way before the mileage). Assuming the special warranty only covers the motor, do I still keep my extended warranty I just purchased because it covers the whole truck, or get my money back and just use the special warranty while taking a risk on everything outside of the motor (suspension, electronics, etc.)?
Responding as a contract administrator, I can attest that MOST failures that occur outside a normal factory warranty, during the 100K mile period, are not lubricated engine parts. Alternators, water pumps, fans/parts, transmissions, differentials, bearings, leaking struts, ABS components, ECMs and other modules, wiring issues, window motors....The list goes on. Engines are far down on that list.
First off, I’d recommend at least waiting until you get the results of your dealership inspection. After that, weigh the risk and do what makes you feel comfortable. I am personally keeping my extended warranty because some of these other components could easily cost more than what we paid for the warranty and when you throw in GM’s track record, enough said.
I read that this warranty would be special coverage and that time frame being 10 year 150k from in service date of the vehicle. So the day it was delivered to the first owner is what would be the start of that coverage.
That definitely makes sense. I also thought about if Knapp (or whoever they use for their extended warranty that I purchased) will give a partial refund due to not needing my motor covered under their plan (cause it would be covered under the special warranty if I pass the inspection). No need for my motor to be double covered.
I read that This warranty would be special coverage and that time frame being 10 year 150k from in service date of the vehicle. So the day it was delivered to the first owner is what would start that coverage.
That's correct. my Knapp Platinum warranty will expire in FEB 2032 or 87,000 miles (which I won't hit mileage wise). The special coverage (if passed inspection) will be AUG 2032.
Speaking as someone who grew up on a farm/ranch and his first job was shoveling grain and shit, never buy an extended warranty.
Instead every day you get into that truck, put $5 in an envelope and save it for repairs. Say you drive it 300 days per year, you'll save $1,500 per year and by the end of the 3 year bumper to bumper you'll have $4,500 saved for repairs. You like that, well now put that same money in a 6 month CD at 5% and keep rolling it over. Now you'll have $6,000 saved for repairs at the end of 3 years. Now you dont have to deal with some asshole selling warranties and some $10 an hour making MFer processing your claims.........hell that's worth $5K alone.
I dont usually offer my best investment advice unless we're close friends, but if you want to save your cash, put it in Redneck Bank (https://redneck.bank/accounts) in Oklahoma they paid 4.50% on deposits. Or leave it in your Chase or Wells Fargo account and get 0.01% on your deposits.
Anyways, follow me on X for more investment advice and life hacks.
Yea...no. That's not going to happen. Those contracts normally provide you with ancillary benefits, such as rental car and towing expense and in some cases, travel expense. What you CAN do is ask how much a full refund would be(it'll be pro-rated), toward the purchase of a WRAP plan (if available). A WRAP will cover all the parts that a 100K powertrain warranty won't cover, such as all the parts I mentioned.
Reactions: KLA
This whole thing is a clown show. 5,000 dickweeds all over the internet screaming like their teeth are on fire and not knowing a thing about what they're talking about. I don't know what the facts are but I'd very much like to. exactly what is the problem? to know what your chances of failure you may have need to know the exact cause. too tight of tolerance, too loose? out of round? poor bearings? crank? it's bad m'kay doesn't get it.
I have 10k on mine now, no problems whatsoever. I put the Range on and changed oil to 0-20 Signature early on. I just changed my oil again at the usual 5k to 0-40 Signature like I run in my TRX and it looked textbook perfect, so I'm not too concerned at the moment. If we do get the 10 year 150k warranty I'm as happy as a pig in chit and I don't give a FF about any of this.
