No more messy straps. Meet powoq retractable ratchet straps
powoq
🌟 Forum Vendor
Hey everyone,
As we all know, traditional separate ratchet straps can be inconvenient to use, especially when you have to manually feed, tighten, and roll up the loose webbing every time.
To make things easier, we put together a retractable ratchet strap setup built specifically for 2019-2026 Silverado and Sierra 1500 beds. (Please note: they are not compatible with GMC Sierra 1500 Denali Ultimate with CarbonPro beds.)
The main idea here is convenience. The setup mounts in your bed so it is always ready. When you need to tie something down, just press the yellow button to pull the strap out, and hook it to your cargo. Then, pressing that same button automatically sucks up all the slack. Finally, pump the handle a few times to lock it in.
It's a solid carbon steel setup with tough polyester webbing that holds heavy loads without vibrating loose. Installation is straightforward since it uses existing bed holes. If you have a driver-side OEM assist handle, please use the front side location.
You can check them out here: https://bit.ly/4yK708V
