bstevens9890
Has anyone installed the peak 2.25" lift and experience a rattle in the front end?
Yes I put the peak upper control armsDid you swap the control arms when you added the lift?
Might be a a given, but I’ll ask anyway. Did you cut off the droop limiter tabs on both sides?Yes I put the peak upper control arms
Did you ever figure out what the rattle was?I was looking at that the plastic peices that secured it doesn't fit any more being the bolts sticking out is a little shorter. I'll figure out a way to secure it. Thanks
Yeah sure did, when I installed mine instead of taking the sway bar apart at the ball joint, I took it off where it bolts to the frame. When I torque the bolts back I guess the rubber grommet didn't seat correctly and it was rattling. Yeah you right I thought maybe it was the plastic peices above the shocks secured them with tie wraps, there isn't really a good way to secure them, but it hasn't been an issue.Did you ever figure out what the rattle was?
After installing my peak kit I did notice those looms and plastic pieces aren’t secure at all.
Good to know.Yeah sure did, when I installed mine instead of taking the sway bar apart at the ball joint, I took it off where it bolts to the frame. When I torque the bolts back I guess the rubber grommet didn't seat correctly and it was rattling. Yeah you right I thought maybe it was the plastic peices above the shocks secured them with tie wraps, there isn't really a good way to secure them, but it hasn't been an issue.
Not to create more confusion but I have the exact rattle/knock exiting or entering my driveway at an angle. & I don't have any suspension upgrades (yet).Good to know.
I separated everything at the control arm when installing. I do hear an occasional rattle/knock when going threw off camber suspension cycle, like exiting the driveway at an angle.
That’s what makes me think it’s throwing those looms around that are no longer secure.
With all the wires and plastic mounting bits under there, it will be hard to pinpoint the problem.Not to create more confusion but I have the exact rattle/knock exiting or entering my driveway at an angle. & I don't have any suspension upgrades (yet).
Was thinking of mentioning something when I decide on a leveling kit and take it to a shop. Don't have much faith in a dealer figuring out where a noise like that comes from.
