powoq 6-Piece White LED Bed Lights for Even Illumination
powoq
🌟 Forum Vendor
Day-to-day truck use usually means dealing with the struggle of a dim bed where it is hard to see your cargo. Having hands-free illumination right over your gear solves that problem.
This 6-piece white LED kit for the 2019-2026 Silverado 1500 mounts into the inner bed sidewalls to get light down where you actually need it:
  • ABS Housing and PC Lens: Scratch-resistant PC lens with a sealed ABS housing to keep out water and dust.
  • 6-piece LED Lights: Three lights on each inner sidewall distribute illumination evenly across the bed.
  • Everyday Utility: Helps you see tools at night and lights up enclosed beds under a tonneau cover.
  • No-Drill Mounting: Snaps into the inner sidewalls with adhesive backing and connects via the included harness.
  • Factory Switch Sync: Controlled by the original cargo light switch, requiring no extra operations.
We only have a limited number of sets available in this run.
If you want to pick up a set for your truck, check it out here: Use code POWOQ10 at checkout to get 10% off your first order.
