Rear End Swing
I’ve noticed since having my ‘23 ZR2, that the rear end swings in the slightest of moisture on the road. Is there a heavy duty rear anti sway bar that can be put on these trucks to tighten up the suspension without sacrificing the way these trucks are designed to operate.
Thanks!
When you mean swing you mean slides out right?
I don't think swaybars will help with that tbh, and any swaybar is going to limit your articulation.
Idk if you're upgraded already, but MT tires in general, but especially the stock ones, aren't worth a shit in the wet.
Get a good set of AT tires with 3pmsf ideally and you'll likely improve your issue a ton.
Or strap a couple sandbags down in the bed.
What you are describing is a tire traction issue in the wet. Tire mod needed.
Any anti sway bar limits travel by design. Counterproductive to the point of these trucks.
These trucks spin the tires pretty easily in the rain. They are not halo horsepower trucks but they do make considerable TQ. Tires will help but your driving style will have to be modified in wet conditions. Or run Auto 4wd.
