- Apr 20, 2022
- 197
- 503
- #1
They’re zero off set. I was going to go with -12, but got talked out of it. I kinda wish I did get the -12 because these don’t go as flush as I’d like. I had 1.5 inch spacers before with my stock wheels and tires and it made the stance look so much stronger (with some mild rub). I just ordered some 1” US wheel adapters hub centric spacers to get some more poke.I like the look! What offset are those rims and if I can see correctly those tires are 285/75R17?
So you were getting rubbing with stock wheels / stock tires and a 1.5" spacer? I thought I had read somewhere else on here that 1.5" spacers with the stock setup didn't rub. Is it a YMMV situation depending on how tightly they fit the fender liners or something?They’re zero off set. I was going to go with -12, but got talked out of it. I kinda wish I did get the -12 because these don’t go as flush as I’d like. I had 1.5 inch spacers before with my stock wheels and tires and it made the stance look so much stronger (with some mild rub). I just ordered some 1” US wheel adapters hub centric spacers to get some more poke.
The tires are 285/70/17. Again, I got talked out of getting 35” tires for the 33s. They’re the smarter choice, because there’s zero rub, and, if I’m being honest, I don’t really want a leveling kit for my truck because I’m having trouble as it is finding garages that I can fit my truck in (I live in a major city, with almost zero parking). The 33s are great, buuuut, let’s be honest… 35’s look way better on this truck. In 30,000 kilometers, when I change them there should be plenty of kits and proper ZR2 specific leveling kits that I’ll upgrade to 35s.
That sounds about right. I did get some rub at both extreme locks with my spacers, but never so much that I was worried. It does sound like a case by case situation with who’s getting rub with spacer by whoever assembled the vehicle. I do know (because of Matt Ross’ YouTube channel) that by removing some auxiliary brackets, some light trimming, with a bottom based lift kit and new upper control arms, you can comfortably fit 35’s that have some very mild poke. He’s done, by far, the most comprehensive work into showing how to work on the ZR2 which, at this point (AEV Bison aside), has zero aftermarket support.So you were getting rubbing with stock wheels / stock tires and a 1.5" spacer? I thought I had read somewhere else on here that 1.5" spacers with the stock setup didn't rub. Is it a YMMV situation depending on how tightly they fit the fender liners or something?
FYI, I threw on some 1.5" spacers this weekend, and I get rubbing on the rear of the fender well on the passenger side when turning full right. Stock wheels / tires.That sounds about right. I did get some rub at both extreme locks with my spacers, but never so much that I was worried. It does sound like a case by case situation with who’s getting rub with spacer by whoever assembled the vehicle. I do know (because of Matt Ross’ YouTube channel) that by removing some auxiliary brackets, some light trimming, with a bottom based lift kit and new upper control arms, you can comfortably fit 35’s that have some very mild poke. He’s done, by far, the most comprehensive work into showing how to work on the ZR2 which, at this point (AEV Bison aside), has zero aftermarket support.
Thanks. I have to be honest, other than the wheels being zero offset, I don’t know how the spacers effect the offset. I’ll take your word if adding spacers contributes to offset measurementThis stance looks good! The wheel is a 17x8.5 with a 0 offset correct? But with a 1 inch spacer it's roughly a -25 offset if I'm not mistaken?
I have had the 1.5 inch spacers on for around 500 miles and have not had any rubbing.I'm really surprised to hear some people are rubbing with 1.5 spacers. I'm running 1.5's on stock wheels and tires and I get no rub at all, and I have stressed the truck enough since putting them on that I should have heard and felt it. When the time comes for new wheels and tires and I am getting the same offset as the spacers provide, I just like how it fills out the wheel well.
Sorry, I forgot to take those pics. Here’s my left frontI believe your setup would be similar to a wheel with a -25 offset as far as how far the wheel sticks out. Is it possible to get a shot of the clearance between the tire and control arm? I plan on 315 tires but want to make sure there is room
I had 1.5" spacers on mine and the front left rubbed in full max, reverse only. I pulled them off until I figure exactly what I want to do. I for sure want to level it but having trouble finding UCA's that will fit. I had a Motofab set and they would not stay in alignment.I'm really surprised to hear some people are rubbing with 1.5 spacers. I'm running 1.5's on stock wheels and tires and I get no rub at all, and I have stressed the truck enough since putting them on that I should have heard and felt it. When the time comes for new wheels and tires and I am getting the same offset as the spacers provide, I just like how it fills out the wheel well.
