2022 6.2 L Scoring cylinder piston
Jun 12, 2024
71
168
50200 miles
On cold start hearing loud ticking noise and when warm up slight noise still. Went to dealer (still under warranty 60000 miles ) and they confirmed noise in and tore apart Moter to find 3 soring piston walls on the left side and small metal fragments on cylinders. What next now waiting on GM to decided next step > Sucks to be me, hopefully they fix it problem.
Just a FYI
Thank you for all the support, hoping all goes well in the coming week and will keep you'll updated on process. I doubt Gm will give me another 60000-mile warranty on a new motor if this what they decide to do, but i will be asking if this is the case.
Wish me luck
When I had the motor replaced under warranty because of dropped lifters on my 2015 Silverado, I was given a 1 year warranty on the motor replacement in addition to the current warranty that I had. Good luck with the repairs.
UPDATE
Waiting on a GM Teck to come to dealership now and inspect and discuss the next steps, (as they told me metaphorical "ball"is in their court) after they now set pictures of souring cylinder and sending service history. Bought used but had a car fax showing all service done at GM dealership on the oil changes by previous owner which were all in good order and well maintained) now going on week 3
Photos of pistons
Going to be along wait before they come out ,maybe another week or so no ETA ,Who knows what the GM text will say to dealership as far a warranty work with this problem on bent pushrod and the souring pistons .
I keep you’ll all posted on process.
Photos of pistons
You get a new motor, you have a damn near new truck! There's some upside here!
Update
Also, a bent push rod which caused the souring of the piston ,still a waiting on Gm to suggest repairs
This may be why it's taking GM so long...They have to send out an engineer to properly diagnose the failure. Bent push rods don't cause cylinder wall scoring. Inadequate lubrication/foreign objects/debris causes scoring. Bent push rods are caused by other things (lifter sticking, over-revving, valve slicking, ). Without looking at it, I am guessing some sort of valve train failure that caused debris to ender the cylinder which caused the scoring...Or you coincidentally had two separate failures at the same time. Sounds to me like you are a customer with a service center that doesn't have a good diag tech and can't provide an accurate cause of failure.
Not the same motor or mileage, but here's another horror story.
This is why I HATE the interwebs. For the love of all things holy, will somebody please tell me WTF "replaced two cylinders" actually entails?
So, this dickhead wants a brandy new truck because two ignition coils failed? Maybe he had a lifter failure? Maybe bad sparkplugs....What the actual F^&% is this clown even talking about?
This is why I love the interwebs..... guys go fucking mental over everthing that other guys already went mental over!
