Barely, at 83 inches over the b pillar, as these trucks sit big! Every truck sits a little different, so you might not clear. Also the antenna might hit, but you can get a shorty.Will a 2026 Silverado 2500 ZR2 Diesel fit under a 7 foot garage door?
I have 84 inches. The chevrolet site says 82.68 for a 2500 ZR2. Hopefully it fits.Your opening needs to be about 83 1/2". It also will depend on your approach angle. Steep entry you might get away with a little less. Chevy said 82" and some change on their site when I bought my 24. Brought it home on a Friday night and spent my Saturday raising my garage opening up about 1" lol. If the FM antenna hits, STOP. The highest point on the truck is actually top of the cab behind the sunroof, But the FM antenna is a little taller. It kind of acts like a curb feeler for roof clearance. Kind of nice if your are out somewhere and aren't sure if you can clear something.
What is Grok?Grok says you’ll have just over 1” of clearance! So depending on the approach or if the door sits just below the opening then you may rub against the door seal. If you can, test drive one and run it by the house for a test fit.
I have 9 inches of clearance on th4 top antenna now on My2023 1500 ZR2. Barely under 84 inches on the header and the garage door travels well past it when opened.Your opening needs to be about 83 1/2". It also will depend on your approach angle. Steep entry you might get away with a little less. Chevy said 82" and some change on their site when I bought my 24. Brought it home on a Friday night and spent my Saturday raising my garage opening up about 1" lol. If the FM antenna hits, STOP. The highest point on the truck is actually top of the cab behind the sunroof, But the FM antenna is a little taller. It kind of acts like a curb feeler for roof clearance. Kind of nice if your are out somewhere and aren't sure if you can clear something.
Elon’s AI chatbotWhat is Grok?
Garages are for sports cars, not trucksLet air out of tires every time you enter the garage and fill back up upon leaving?
Yes when we had our current house built I had an extra 4' added to the depth. My 2025 Silverado 2500 HD with the standard bed fits with plenty of room.Define trucks! When I lived in ID I could park my trucks in a garage; short and standard beds. Now in AZ I could fit a sort bed in the garage but not a standard all due to depth of the garage; not height. My next move will be to a house with a garage that will accommodate a standard length truck.(And that moved might be coming sooner than expected....
It was 4 feet not 4 inches.Don't believe 4" will do it for me.. My neighbor backs her 1500 in with a short bed and has less than an inch. Believe there is about 10" difference. I pull mine into the garage only for oil changes to get it nice and level.
