andrec10
Well-known member
Toyo lists these as a plus Zero size. Does not look to be any rubbing issues with no mods. Can anyone chime in?
Thanks!
Thanks!
Which Toyo tire? I know some guys were running 285s, but may have been the Nittos or Mickey's.Anyone?
good infoI’ve run those Toyos and the Ridge Grapplers on my HDs. I’ve probably put a hundred thousand miles in trucks with both tires. My experience has been the following…
They both seem to wear pretty well, I don’t run them bald as I drive too much in varied conditions but 45-50k miles seems pretty reasonable to me, especially if you rotate and maybe even want to push them a bit.
Ridge Grapplers performed much better off-road on the farm and hunting throughout the mid west - specifically, I was stuck 4 times in the Toyos (twice snow and twice in mud) and none so far in the Ridge Grapplers. Given the mileage and length of time using both tires across different trucks, I feel like that’s a pretty real world comparison. Maybe I was just unlucky in the Toyos but again, multiple trucks, lots of miles, etc so I don’t think so. Toyos on my 3500 SRW would break loose in rain occasionally with cruise set…I didn’t like that at all (probably not advised driving habits…shame on me, no issues with other tires)
I put the Ridge Grapplers on the 1500 zr2 to see how they do on this truck. No complaints since December with 5,500 miles. I just swapped the Toyos off my GMC HD and went with the Falken Wildpeaks at3w to see how they do this time around. I use that truck (3500 sing rear wheel primarily for pulling trailers and occasional road trips as it’s super comfortable). They seem like a solid option so far for an all terrain tire…if I don’t have issues, I may stick with them as they are snow rated as well.
Hope that helps, I’m no tire expert, just a dude that uses trucks in various conditions over a year
