6.2 Recall Letter
They had another ECU and pulled the range module and did the reprogramming. I'll be picking it up in the morning.
They did say the range DFM module contributed to the bricked ECU. But said they would warranty the part. I've always had a good relationship with the dealer and SA, so I suspect they went to bat for me here and I appreciate that.
I'm not so sure it did cause the issue, cause there's plenty of examples of them bricking during updates. Also I've had it in twice for other updates and told them it was installied. However, I will accept my share of the responsibility because I knew they were going to update the ECU cause he told me so when I checked it in. I should have reminded him it was in there. I also knew that Range recommends removing it for any work done using the OBD II port, which is basically everything nowadays. I should have pulled it and played it safe. So I'll own it!
Also found out that the Tahoe will not require the ECU update. I guess its VIN specific. But I'll plan to remove it anyway cause it only takes a few minutes.......live and learn.
Reactions: KLA
If you have a good rapport with your SA it is always good to let them know any modifications you've made. I've always told mine when I brought it in, but never had an ECU update either...so I guess that's that eh... Anyway glad you got it squared away and happy for you that they took care of it 👍 I disconnected absolutely everything aftermarket that was installed when they ran the Pico test on mine. Any other time when I brought it in and had any other work done....I've just left my Range disabler on also, but made sure they knew where it was and how easy it was to remove. You dodged the bullet on this one 👍
I got my letter 3 weeks ago but still haven't had the time to take my truck in for the pico test and service. Will do it soon.
I'm sure we're all just getting thicker oil which is a crock of shit. Kick this can down the road long enough for all the engines to blow at 150,001 miles and they're off the hook.
I’m getting my new engine this Tuesday.its been 3 months or so since they told me mine failed the inspection
Took mine in last week, got a clean bill of health. Got the filler cap, and the sticker and a 10 year warranty. Personally, I’m glad I passed as I needed my truck because I was moving into a new home, but I’d be lying if I secretly didn’t want a new motor. Either way, I’m sorry to hear some of you guys have been having some negative experiences with this ongoing situation.
The test is designed to appease the NHTSA. You may still get a new motor with time. No one is “in the clear” with a passing pico scope. The extended warranty is the only thing of value. Does anyone know if the warranty terms are transferable to the next owner? That would certainly help our resale.
