6.2 Recall Letter
Had mine done yesterday. Took roughly 5hrs before I got a call saying it was ready. Engine and ecu both handled. I passed. Manager said two have failed so far down here in south MS. One came in on a flatbed and the other was making a loud clunking noise when dropped off. So, not necessarily found during recall just failed engines. Crazy part was dealership I bought the truck from called and said they needed to address the recall and it would only be an hour. My local dealership, where I get all my work done, said standard 3-4 maybe a little longer. I told first lady she better check her times. I'd be pissed sitting there for a one hour job and it takes 5. Good news is I was due for an oil change so got that one done for free!
My '22 passed the PICO test, but the ECU update fried the computer. I had told my SA about the Range device, he thought that might have done it. They removed it when the replaced the ECU, and he made sure the tech didn't record any mention of it being there just in case.... Amazing what a bottle of Makers Mark does to grease the wheels!!
I would certainly think that anytime an ECU update needs to be done, the Range should be removed. The ECU isn't looking for it and doesn't know it's there and an update may very well create an unforeseen issue as it did in your case. An ECU update from the dealer should never "fry" an ECU unless something is amiss.
Dealer just called and claimed they cannot perform the N252494000 (L87 Engine Loss of Propulsion) recall because GM is "updating the procedures." They cannot do any recall work until they are notified by GM.
Anyone hearing this? WTF
I called GM. The Rep's solution was to "just go to a different dealer." Thinking about selling my truck and buying a Raptor. Tired of this nonsense
I would certainly think that anytime an ECU update needs to be done, the Range should be removed. The ECU isn't looking for it and doesn't know it's there and an update may very well create an unforeseen issue as it did in your case. An ECU update from the dealer should never "fry" an ECO unless something is amiss.
100% agree. I just kinda spaced on it....
Except there are now three of us with fried ECUs with the Range Module installed.....me thinks it's a problemo!
Don't recall seeing this noted anywhere in the thread, so thought I'd share. ECM software update N252510321. My understanding is this will provide the driver with a message in addition to the check engine light when the diagnostic code P0016 (mismatch between camshaft & crankshaft) is detected. Update started rolling out around 08/14.
Makes sense! I knew they mentioned that on a couple YouTube videos I seen. I think one of them was feom Don's Life.....he's pretty thorough in his analysis.
Reactions: KLA
