Auxiliary accesory bus bar install
Hey all
Putting out a question to the brains trust-
My positive and negative terminals are getting real crowded. Currently my positive has a garmin powerswitch and an air compressor wired to it.
My negative terminal has my powerswitch, ditch lights, compressor, compressor relay, and GMRS radio wired to it.
I still need to wire in 2 sets of fog lights and a winch.
My plan was to to install two big bus bars wire to the battery and earth that i could spread out my connects across, however space is tight, and it's looking like I'll need to fabricate a bracket.
However before I go to that length, has anyone got any suggestions for a pre-made mount that might do what im trying to do?
Im good at alot of things, but fab work ain't one of them.
Thanks for your help.
Hey all
This works well. I've used them a few times. Pretty well made and will handle fuses and negative buss bar
Thanks for the suggestion. I dont think it'll 100% suit my application- both the winch and powerswitch draw too much current for what that's rated for.
But it's a definitely an option im going to chase up - see if there's something similar for higher current.
Thanks again
Thanks again
I would run the winch off the factory winch location. Have you added the extra posts to the factory distribution panel on top of the battery?
You're 100% right. Definitely will run the winch direct.
I have not, though I'm not sure I'm able to.
Roughly where would they go in this image? And if you see a spot open is there a specific part number?
The winch location is the one on the left (passenger side) the one on the right is for the factory upfitter switches. You can order just the posts and fuses in a kit on ebay. BTW you might can find it cheaper. I didn't really search around. Just posting so you know what your looking for.
Ebay link
Hey all
Maybe you want to add a second battery. I get worried about tying everything into the main battery. I suppose if its overloaded it could be damaged. I was told that electric assembly on top of the battery is really expensive, but can't recall the exact price. Damn near impossible to change the battery anymore.
I've thought about it tbh.
However I don't think it'll be necessary, I'll hopefully never be running the winch, compressor, radio and all my lights at the same time, so the load at any time should be pretty manageable.
If I was running more things with long constant draw it'd be another story, but it'll really only be lights with brief spurts of winch and compressor.
The big draw would be the winch- I know they can get up to several hundred amps under high load.
So will have to use it smart, taking breaks. TBH I'm kinda concerned that the power wiring that was sent with the winch (Badlands Apex 12k) isn't thick enough for the application. It looks like 2awg, and the cables are pretty long to reach the battery
Update for those who care
Ended up buying a plate of 1/4" aluminum from Amazon and fabricating up a bus bar mount/ bracket/ plate.
Made a template with cardboard then cut the outline with an angle grinder and a cutting disc. That didnt work worth a shit, so I moved on to a drop saw with a friction disc.
That failed too, got pitched across the yard and is now in two pieces.
Couldn't use a hack saw because the frame of the saw wouldn't allow me to go deep enough- so I bought a milwaukee hackzall, which got the job done pretty easily.
I hate aluminum.
The plate mounts to the driver's side battery bolt with a washer to space it up slightly.
The passenger side has a slot cut out that the raised side of the battery strap slots between- stopping any rotation.
It's crude, but it'll do the job.
May clean it up and paint it or redesign in CAD and get cut by send cut send or someshit.
Probs gonna relocate my powerswitch from the fuse box to the plate too- not sure if I'll have time prior to the 4th however.
That should work. It's kind of hard to make everything look pretty when adding a bunch of wires under the hood. When you add your Bus bars just keep in mind access to swap out the battery easily. On my HD I added a auxiliary battery. But I had to make a battery strap since the OEM ones where on indefinite back order at the time, lol. So I ended up making the battery strap so my Fuse blocks bolted to it. That way when I remove the strap all the extra stuff just swings out of the way with it to pull the battery if I need to. Kind of the same idea as your bus bars though. I have one 1/0 gauge wire to the battery that feeds the blocks. They act as bus bars, but just have all the fuses right there for easy access to everything.
No room really on the 1500s to add a aux battery. At least not under the hood. I had a aux 30ah Lifepo4 on my 1500, but it was mounted under the drivers seat. I just used it for dash cam and charging ports in the truck to keep from pulling the main battery down while the truck was off. I had my compressors, stereo amps, ect all on the main battery and never had a issue. Would be nice if the 1500s had a spot for a Aux battery though.
Luckily the only bolt holding it down is the battery strap,
So as long as I leave some slack on my accessory leads then it should be easy enough to just fold out of the way.
I decided against fuse blocks just because of space requirements- may change that in the future with v2.
