Engine Block Heater for 6.0L Gas Engine
I know it is mostly used in diesel engines but simply curious.
Does the ZR2 comes with engine block heater pre-installed? If not, does someone know how simple/hard it is to install and related part number?
Not gas engines.
Mine has the connection like YYCZR2 said, also the cord is under the back seat.
I'm assuming it's hooked up to the block, never traced it out!
I know it can be point of delivery dependent. If your in a colder state, you most likely have one.
In ND, everyone had a block heater. If you didn't, you better have a garage at home and work. It's a bitch starting something below 0, not to mention how hard it is on them.
  • #6
I was reading the specs online, and it seems like to be an option. It doesn't show in my ZR2's Window Sticker and I don't see any cord under my vehicle's back seat. But, will check again.
Correct...it is not standard equipment.
