KLA
- Oct 5, 2024
- 704
- 1,682
Right now my truck is running fine. But if something happens to the motor, I sure as hell don't wanna be charged for it just cause I put an additive in the oil. Just not gonna do it.That is a good point... GM and I certainly hope they do not put this into the final repair procedure -- oil test. GM even if they did do an oil test would give the nature of the failure another "possible" contributing factor to the failure and try to charge the customer for a portion or all of the repair based on what the analysis shows. As expensive as this recall is going to be you can rest assured it is all about $$$$'s no matter what the GM spokesperson says!
That being said GM would be very hard pressed and the bad press that followed would also cost them $$$$'s. Nothing that GM does with this monster will surprise me.
