Headlight adjustment
Recently lifted the truck how do I adjust /aim the headlights ? I did a search couldn't find anything....thanks in advance
There usually some adjustment screws on the back or side of the headlight housing. You may have to pull the plastic cowling under the hood to expose the screws.
May want to pull up a parts list diagram and see what the headlight looks like.
Actually just did it after my Peak spacers went in. If you look directly down behind headlight assembly under the hood, you can see the 6mm hex head screw. Twist it and you'll see your beam move up and down! Simple
