Issues with 1 in Peak Lift Blocks w/ 1.5 in Deaver Leaf Springs
Hopefully I can get some solid input on my situation, and assist me with a way forward.
Recently I had installed the 1.5 inch Deaver leaf spring upgrade and realized the truck was still squatting a little bit, so I went ahead and ordered the +1 inch block from Peak suspension. Installation was easy and pretty straight forward, but after installation, there is a thumping sound that occurs ONLY when going over speed bumps between 1-3mph, and the passenger rear seems to go through more range of motion compared to the driver rear when going over bumps. I checked the torque on all bolts/nuts (Peak recommended 85ft lbs on the U Bolt nuts and 118ft lbs on the lower shock mount).
I continued to roll with it after having my mechanic take a look over my installation work, said torque on everything was good and he didn't hear anything going over bumps, which led me to believe this sound after lift blocks was normal.
I want to note that I have not noticed any performance issues with normal driving, no extra vibration or anything. I have yet to take it on any gravel roads or anything that I normally would for work due to the fact that I haven't needed to, but I'm reluctant to when thinking about it.
Fast forward to today, I noticed that the tops of the U Bolts that wrap around the top of the leaf are more pinched together on the right side than the left side, I have pictures attached for a visual example. Additionally, since I have coke bottle glasses, I verified by measuring with the length of my deep well socket, and surely enough, the length +1 inch fits on the left side, but the right side cant fit the socket at all, even by itself.
So the conclusion I have arrived to is that the problem is 1 of 2 things, or possibly a combination of both :
- The U Bolts on the right side being pinched inward on top of the leaf
- The shocks topping out due to them not being rated for more than +2 inches of lift, while I currently have 2.5 inches added.
I also want to note that there are no noises that occur upon acceleration.
I am working with peak suspension in the mean time to see if we can do an itemized purchase the rear shocks that are meant for the additional 2.5 inches, while I find a way to adjust the U bolts to me more even without having to jack it up a whole lot.
What do you all think?
***ADDITION***
I have also considered taking the peak blocks off and putting the stock ones on, Peak claims that they are compatible with the deaver leaf springs.
Peak replied to you? Thats crazy talk.
On another note, I have the same blocks and my axle is swinging quite a bit forward and back when I offroad. I'm just going to have a custom set made to eliminate the need for blocks.
What do you mean by swinging? What tells you this is happening?
So your whole axle is moving forward and back? I'm not having that issue I don't think. What is your plan to deal with that? You mentioned the custom blocks?
Yeah just enough to rub the crap out of the fender.
I meant a custom set of Alcan leafs, sorry. They run 1400 and they build them to your lift and weight. No blocks needed
I see, Ill keep that in mind. It would suck to have to take the deavers off right after i installed them. Anyone else have some ideas?
If the squatting is due to heavy cargo or towing, you might want to consider eliminating the blocks and running air bags to keep the rear supported and level.
I don’t tow anything or plan on it, the squatting was from the front end having a ready lift spacer and the rear having nothing. The previous owner wasn’t the smartest and I have been chasing a solution for a while now.
Call Cognito and ask them about it. They sell Deavers springs along with all their lift gear. They might have a solution.
Ill look into what they can provide
What do you think of the pictures i have attached? Should the position of the U bolts be a worry?
They don't really look off to me and the bolts look heavy duty and quality. The problem is you have something square sitting on something round, so there is gonna be some horizontal articulation under stress.
I think what you're hearing at low speed over bumps it the heavy springs flexing. On my prevoius lifted 2500HD, they always sounded worse at slow speed with bigger bumps and more articulation. On my ZR2 2500HD it is hardly noticable I believe due to the Multimatic Shocks and softer rear springs.
Interesting, I wonder if any of this is worth the stress then. I know some people have said that a thump after installing blocks has always been a thing, but my main worry now is the shocks topping out.
You might have the wrong Deaver spring. This one shows a mini pack if your only trying to get 1-3 inches.
That big stack you have would be for a taller lift and heavier loads. Thtas whyI was wondering if you're towing.
Here' how they list their heavier Spring stack .
When I had my deavers delivered I did notice that, it only provided 1.5 inches difference with these deavers according to peak. But the ride quality is awesome, but they are obnoxious.
These are what I have, I also want to add that they certainly are NOT quiet. These things creak more than any leaf spring set I have used
There may be different springs than what Cognito is selling. You would have to compare part numbers to be sure.
When I see that many leafs, I immediatley think heavier springs like on an HD. I guess it depends upon the strength and tempering of each leaf for each application.
Did you get the pinion shim? It could be that your hearing your drive shaft bind up, because it is no longer in alignment.
There was no mention of needing one so I didn’t even think of that, what i might do as a temporary solution is put the stock blocks on and take the peaks off.
From what I have seen though, theres no mention of pinion shims on any lift from peak suspension.
Is there a way to replicate anything with the drive shaft shifting up?
