Krown / Fluid film undercoating
Hello,
Very proud owner of a 23’ black ZR2 Just looking for some ideas on what others have used in states with salty roads.​
I sprayed mine with Cosmoline RP-342. I like it because it hardens and doesn’t leave oily residue like wool wax does. Plus it’s thinner and sprays easier. We will see how it holds up long term
I wouldn't use Fluid Film or any other petroleum based coatings. It will break down the grease the factory uses to coat the frame. Don't ask me how I know. Still searching for a good product that is compatible with that coating.
I use Krown on my Zr2 and used it previously on an AT4 I had. Happy with the results, did what it needed to do.
I use Fluid Film on everything but the frame (due to the reason mentioned earlier regarding the factory coating impact)…it’s great for certain areas IMO.
While I don’t disagree with the idea, the factory grease coating does a pretty good job of breaking down by itself. I think it’s important to reapply as often as necessary, probably yearly, but I think other coatings do a better job for longer than the factory
This is what I use. I did a lot of research and found this to be the best in my opinion.
Corrosion Free Rust Cure Formula 3000 1G/4L Jug, Great for Vehicles, Buses, Tractors, snowblowers, mowers, Rust Prevention, Rust Inhibitor, undercoating https://a.co/d/1GR5xJM
