Looking into the Peak 2.25 lift.
2024 ZR2 Bison 3l in Black.
Thanks for the add.
I pulled up next to an identical 2024 bison with the 6.2 and it was at least 1.5” taller at the mirror? Any thoughts?
The Peak 2.25” kit is an awesome choice. I had it on my 2022 ZR2 and have ordered it for my 2024 ZR2. On my ‘22 I went with Cognito ball joint upper control arms. On the ‘24 I’m going with the Dirt King ball joint UCA.
I’m not sure I follow you. Lift will help in clearance of larger tires.
If you want a lift to clear 35’s you probably need an additional 4 inches. If you go less than 4 inches you will cut all the same things the rest of us have (discussed ad nauseam on this forum).
My shoes are 35.1 tall and 11.5 wide. I have zero offset rims and a 1/2 level. Trimmed rear front wheel well plastic, removed the liner plate thing, shimmed the bumper, and cut and welded the crash bar. Another 1 and a half of height would have made zero difference.
I wish you all the luck though.
I am also running 35s but with -12 offset wheels and more than a 1/2” lift.
Additional lift will help but minimally.
No luck needed.
Thanks for the add.
The suspension in my 22 has settled significantly since new. If I pull up to a new TB it looks lifted next to my truck and I have 34’s
I kind of feel the same, but haven't taken measurements. I also feel like the rear is softer. When I stab the throttle, it lifts thr front end more. I've only got 13k on mine.
Might be a good idea for that thread. I’ll have to get the tape measure out
If I recall I think I posted the the measurements for my truck when I did my tires and wheels. If not, I may not have a basis for making a good assessment. Overall, I still feel like it rides good and has decent handling characteristics.
