Low Oil & Check Headlight indicator
Just before the last two oil changes my low oil light came on forcing me to add a quart. The last time was maybe 2 days before my scheduled oil change so I wasn't all that worried. This time I have 20% to go for my next change. I added a quart. Couple days later I park in my driveway with my front end forward on about a 15 degree slope. Fire it up to take my wife to work and check engine light was on all the way there and back. Did it again when I parked similar. This morning I Check the dipstick and oil is low so I added another quart to get it to halfway on the mark after I ran an errand, vehicle was on the flat level surface overnight and through the trip. It's going in on the 12th already for the hood issue where the scoop is rubbing and etching the corners of the finish. 2022 6.2 L Almost 33,000 miles on it. While they have it they are going to service it, perform 3 recalls (Trailer brake, daytime lights etc). Also with a problem I have with the left front headlight, when it rains a few hours later I flip the turn signal on and it flashes quick and message Check Headlight message pops up. Dealership has not been able to recreate that issue. I was going to yank the headlight and look it over for cracks or broken seals in the headlamp assy before its out of warranty.
Almost a 6 months back I remember talking to another owner of the similar truck that was frustrated with the dealer could not figure out why his was burning oil. Just a few days ago I talked with a guy that had a 2024 with a couple hundred miles that had the oil pump go down on it. I was wanting to see if anyone has heard of similar for both the oil and headlight issue and what the resolutions were. I'm so close to the 36K warranty that I want to figure it out before it goes out of warranty.
If you’re waiting for the oil life gauge for your oil changes, then it’s common to burn a little oil. I say little, like a quart possibly more. I do oil changes every 5,000 miles, regardless of the oil life remaining. I also check my oil level randomly between oil changes. You need to pop the hood every once in awhile, check fluid levels and conditions under the hood for preventative maintenance.
As for the headlight issue, I hate when dealerships say they can’t replicate the problem. Sounds like your assumption that there is water entering the assembly is spot on.
Sorry about the issues you're having. I agree that you've probably got water intrusion into your headlight assembly. But I have to say, when I saw the title, all i could think was your blinker fluid was low... 🤣🤣
I've determined mine uses about 1/2 quart per 3k thousand miles. At one time I thought it was 1 quart, but I've captured the oil at the drain and measured it to be sure. Also, my dipstick doesn't read right or consistently. I park right next to my wife's 6.2L Tahoe and hers is spot on, but mine never seems to look full right after a change.
Service Advisor I've known for 27 years said that the new 6.2L motors would be in spec at 1 quart per 2 k miles. It used to be 1 quart per 3k.
If I was you, I'd change my oil earlier and don't worry about adding. If your doing 6-7k intervals following the DIC, I'd assume adding 2 quarts might be right.
I drive mine harder than some, so I expect a little blow by to be normal. If my wife drove it, probably be the same as her rig.
So the dealership thinks the headlight and check engine light is because the onstar module is out on it. Friend in the body shop took care of the hood service bulletin and wheeled it over to service where they could only do an oil change. They did not do the decal flash for the trailer brake, daytime lamps etc because they had one vehicle with the o star out and would not accept a successful flash and vehicle would not start. No ETA for the part and 2,000 miles left on the warranty now. They said come back before out of warranty so they could open a ticket.
Looking on GM forums and seems like several others in the same boat. 6 plus months with gps, maps, onstar not working with check engine lights etc. lots of them out of their warranty period.
So update. Onstar parts in. ODO is at 35,024 and checked oil after 1,000 miles. Looks like it’s already 1/2 quart low. So 5qts get used up between changes? Not right. Talked to friend that is the F&I director at the dealership and he told me his 6.2 demo would throw a little puff of smoke when he started it but GM said it wasn’t loosing enough. seized up on the new owner at 62k miles. So, goes in next Tuesday to get onstar module put in hopefully that will take care of the onstar, intermittent left headlight and intermittent check engine light issue. Start with another fresh oil change and have to bring it in to check oil lever every 100 miles.
Perfect timing for the 6.2 recall yesterday. Already scheduled last week to go in this Tuesday to start eval for excess oil usage. See how it turns out. Thankfully I have an extended platinum bumper to bumper warranty coving to 109k or 2029. But at 35k miles now I’d rather not have to pay $100 deductible and I have my hunting rig brought down from the cabin to drive if they swap the engine now.
So back from my dealer. Replaced the Onstar Module, Recall N242435631 Data Gateway Module, Recall N222389722 Transmission Body Screen Failure, Recall N252594000 L87 Engine Loss of Propulsion= No Cam Out of spec code, Parts ordered (Oil Cap) changed oil to OW-40 monitoring for oil consumption currently increased to 1/2 Qt per 1000mi
Talked to a couple of the service techs. Only vehicles getting new motors are the new ones on the lot, everyone else with an engine that tests bad is rebuild. They made that sound like it's no big deal to them or tried to downplay it. The said they showed my notes on how my oil consumption has steadily increased to a tech and he said it was normal for these engines. Service advisor was hesitant to accept that and said I should change every 5k. I asked, "If GM has been marketing for decades now to change the oil when the meter tells you and that is set at 10k miles and Delco has been marketing that their oil is good 10,000 miles...." Get my point. Even so, 1,000 miles in and already 1/2qt low already is on pace for 5Qts per 10,000 miles. I have not had an engine that used that much oil since a 1973 Plymouth Duster 318 with a leaky rear main seal in high school and left a puddle on the ground and blew a puff of blue out the tail pipe when I started it. No answer. I think GM is blowing smoke up our azzes boys!
