- Feb 21, 2023
- 5,922
- 14,286
Can you post pictures of the tang and install procedure. Might be helpful if not available elsewhere.You say they are flush, but you don’t say that the clip is seated into place, both of mine needed to have the end of the clip tang pushed up a little hard to flex the elbow enough to get them to fully seat and click into place, the drivers side went easy, the passenger side took a bit of pressure, I used the tip of the little screwdriver to push up on that tang tip, these lights the tang is just a little lower than the factory ones, but once in place are solid.
