New video with GM insider info
Kind of a secretive fucker, most of that information we've known about for some time. Outsourcing and QC have been a shit show for a long while now, most notably post 2018. Every vehicle has a sticker with the % of foreign made parts, many of which would be "outsourced".
True, but I thought it was interesting the guy named the plant in Mexico that was churning out bad cranks. And you are 100% right about QC, GM let this shit go on for years while people's engines were blowing up - the QC is all on them regardless of where the parts were made. Somehow that never seems to make it to Mary's bonus though...:unsure:
With respect to that crank, I haven't really heard the cranks were bad, just the bearings. I've heard misaligned con rods, which could imply bad cranks.
I'd have to listen to the video again, but I felt like this was a UAW North American whistleblower complaing about outsourced manufacturing, cause it likely goes to non union shops. Wasn't much meat on the bone regarding how they know the cranks were bad.
Maybe we'll learn more in the next video as he alluded, but this didn't tell me much.
Our trucks are built in Mexico! I am not convinced that is the problem. It's penny pinching and bad QC. Suppliers can be held to high QC standards if there's a will.
My motor says built in US, so I presume Indiana. The crank had 6000 miles on it before the truck was built....LOL.
Could be, but it seemed to be more from GM corporate than on the build floor. I doubt we’ll ever know the real truth. I just want my 10Y/150K warranty!
Look at my latest post on the recall. Only remedy is a new motor. No oil viscosity change.
@landpilot you were 100% right on crank being out of spec and journals not polished correctly. Lots of info on that topic in first few minutes of video. No real details on the specifics of the out of spec tolerances, but could be random and affect one or more cylinders due to machining equipment wear or tooling bits or abrasives.
Some more good info here in this video. The consensus is it's a total disaster and no way to know what engines have the bad cranks. Ultimately, some may have had a quick polish to bring them into spec before install, but they are subject to fail cause they were out of spec from production factory in Mexico.
I watched that video today. Lake Speed Jr (Dr. Oil) has a great description of the problem with the finish on the cranks and why some may have made it by and others not so much (casting too rough, sanding belt worn out) and then how different oil viscosities play into that. And how CAFE rules for mileage vs number of units sold helped dictate the oil used instead of the intended use of the vehicle.
Yes, it's a clusterfuck. Sir.
I thought it was interesting that at the beginning he mentioned some inside sources, then proceeded to tell starting a 7:00 that the out of spec cranks were sanded/ polished at the Towowanda plant in an attempt to get them back in spec. That's pretty specific shit that not everyone would know. It'll be interesting if the court cases proceed, if we'll ever get the full story on this shit show.
#N252494001-01 Safety Recall - L87 Engine Loss of Propulsion.......On new vehicles not yet sold, the service procedure 1st step is to check for DTC P0016. This code means the ECM perceives the difference between the crankshaft position and camshaft position to be greater than spec. The ECM determines the position of the two shafts using information from a crankshaft position sensor and camshaft position sensor. it has also been deemed necessary from GM that this recall be determined by use of their PicoScope with the special GM harness.
For those not familiar, a PicoScope is GM's version of an oscilloscope. It does more than that, but at it's core, that's what it is.
If it has this code, it is supposed to be quarantined and cannot be sold.
I'm not an engine scientist, but it seems conversations about crank misalignment would be valid.
Then again, this assumes that the engineer that wrote this memo is 100% correct in failure assumptions.
