Newbie with questions
Some back ground, I buy a new full size truck every 10 years, my last three have been Toyota's, but with the new v6 twin turbo and the new body style no longer a fan.
After much research I landed, picked and finally test drove a ZR2, wow what a truck.
But....then I find out about the recalls on the gas engine and the dealer says now worries its a 2025 and if anything happens they will fix it. (I'm sure he will be there is I break down in the middle of no where, lol).
So thoughts on the engine recall (toyota doing the same), longevity, reliability, what do you think?
It's the world we live in, there are no guarantees with quality anymore.
If you like the truck, buy it and have fun. I would trust the 2025 model a little more since they have publicly stated they have addressed the cam and rod bearings issue.
It's rare to see anyone with lifter issues lately. You can get the Range Module for a few hundred $$ to deactivate auto start/stop and the cylinder deactivation, which helps with reliability and annoyance.
I can guarantee you'll have more fun driving the ZR2 than most other trucks with the 6.2L motor and Multimatic DSSV suspension.
The start of stop was annoying when test driving, when I asked the salesman if there was anyway to shut that off and he said no. I will have to give much more research into the range module.
My decision was between the 6.2L or the Duramax, no true towing but do a lot of highway driving.
On my ZR2 there is a button that turns off the auto stop/start function. You have to press the button every time you start the truck. Every other year ZR2 has the same button. I would assume the 2025 does also. Don't know why the salesman would not tell you this. The switch is in the row of switches under the infotainment screen. It has an A with a circle around it.
The 2025 has the auto start/stop button on the row under the infotainment. I went with the Duramax. Love it so far.
Whether you get the diesel or the 6.2, there's an easy fix to the auto start/stop. I went with THIS one and it works fine. It's a bit more costly than some of the others (yore dropping $70K+ on a new vehicle, what's another $100?) but reading this forum, there seems to be issues with the other one(s).
Highway driving? I'd get the diesel. I get 21+ mpg out of mine on rural roads. I've taken it on one trip and got 27 mpg. You do whatever will make you happy, though, to each their own. I had the 6.2 prior to the diesel (my '24 6.2 was one of the imploders so I unloaded it as soon as I got it back and found a deal on the diesel), but I gotta admit, it was more fun than the diesel. The sound when in performance mode and the sit you back in your seat quickness was a blast. The diesel doesn't run bad at all, though, and has more torque than the 6.2 so is actually better for me as the main reason I wanted one was to tow my boat 380 miles round trip a dozen times a summer. Plus, I'm sure I'll get better fuel mileage with the diesel when towing. First trip for the diesel coming up in June. The 6.2 made 1 full trip last summer later in the season. The first trip in June is when the engine let go and I was without the truck for the most part of the rest of the summer.
Diesel fuel is cheaper than 93 octane, which is what is recommended for the 6.2. However, DEF is an added cost, but think I've put maybe 5 gallon of DEF in it over the 3K miles it has on it (~$20 or less for a 2.5 gallon jug). Oil change can't be much difference in cost as the 6.2 holds 8 quarts and the 3.0 holds 7.
Again, at the end of the day, get what makes you happy and put one of those auto stop eliminators on it.
I test drove the 6.2L fun but I'm going to test drive the 3.0 duramax this weekend, looking for one in blue.
The 2025 6.2L is exempt from the recall. Supposed to be a reliable motor. Not sure if I believe it, but that's what they say.
