- May 25, 2025
- 3
- 3
Window roll down works. Auto vent fan does not. There is no menu for auto fan
Has anyone actually tested this? I did the update. It doesn’t appear to work. Windows down. No fan. Ideas ?
My truck just offered the update and it completed successfully, my guess is that as with all the other climate control functions it will depend on the temperature. The vehicle will not turn on the climate system, the steering wheel and seat heaters unless the temp is below 54 degrees (I think that's the correct temp), and likewise it will not turn on the AC to high during remote start unless the temperature is above a certain temp, I am guessing this feature will not work unless the cabin temp is above a certain amount also.Window roll down works. Auto vent fan does not. There is no menu for auto fan
Is this new update for all ZR2's, or is it just for the 24-25 ZR2's? My ZR2 is a 2022 and I have not yet been offered the update. Of course I can put the windows down with the key fob, but still have not yet got the update. Or maybe they are offering it by model year, from new to old.My truck just offered the update and it completed successfully, my guess is that as with all the other climate control functions it will depend on the temperature. The vehicle will not turn on the climate system, the steering wheel and seat heaters unless the temp is below 54 degrees (I think that's the correct temp), and likewise it will not turn on the AC to high during remote start unless the temperature is above a certain temp, I am guessing this feature will not work unless the cabin temp is above a certain amount also.
I also think the better option for me in hot weather is to just double unlock to get the windows down, and then lock it and remote start it, that way the actual AC comes on instead of just the fan.
It should roll the windows down with the key fob even without the update. Press the lock button once, then press the lock button again and hold it and the windows should roll down. No update needed for that feature.Mine won't roll the windows down either. Not really something I am missing anyway.
