Peak Summit with Air Lift 5000
Anyone run a peak summit system with air lift bags? Anything needed to make them fit or will they still just bolt on? Thanks!
Are you using daystar/RC cradles? And are you using the trailboss or the regular Silverado kit?
The peak system has a taller rear block rear block so you may need to use a spacer to match.
So if I’m looking at this correctly 8ball made a post with his setup and he had to switch to the standard mount for his bags because the daycare cradle took up to much room. With my peak setup I’m hoping that the cradle with the trail boss mount for the bags will fit perfectly. Hoping someone is running it with the peak summit system to clarify.
