- Feb 21, 2023
- 5,937
- 14,321
Congratulations GM you've succeeded in turning an otherwise reliable HD truck platform into some cheap plastic junk that looks straight outta ChiNa.
The more I work on this truck the more I scratch my head on the chicken shit design and manufacturing incorporated to save a few pennies.
Last couple days doing some wiring, so was under the hood and realized how many poor plastic parts were assembled supporting a $15k motor that GM had to buy from Isuzu.
The hood latch release handle is plastic and is bolted to the release. Is chintzy as hell and already loose. How in the hell is it cheaper or easier to marry up two parts using two screws instead of stamping one metal part like the last 100 years.
The plastic radiator shroud appears to be separating from the radiator and I think it's noticeably worse now than before. It might be warping due to heat in the engine. They couldn't even get ChiNa to produce a plastic Radiator hose connection the same diameter as the hose, so they stuck the hose on crimped the hose and sent her!
You've already seen my complaints about the 22 plastic bits on the Bison bumpers , the plastic fuel doors with no caps, and all the excess plastic trim attached to the hood and body panels. I guess I could go on for pages and probably will as it disintegrates before my eyes.
If this POS makes it til the end of 2024 it's gonna be by the grace of God!
FU GM for ruining your flagship truck to divert the profits to your DEI, social governance, and WEF climate bullshot agendas.
