powoq
🌟 Forum Vendor
- Jun 24, 2026
- 20
- 15
- Moderator
- #1
Hey everyone,
Is anyone else dealing with this frustration? Cleaning the factory felt wheel well liners after a trail run is a massive headache. While they might help with sound dampening, that fabric material acts as a trap for mud, pine needles, and trail debris that you can never fully wash out.
To fix this, our team designed PE Rear Wheel Well Liners as an easy-to-clean alternative for the 2019–2026 Chevy Silverado 1500 with a 5.8-ft bed.
Crafted from durable PE material, our liners provide the same full coverage but feature a smooth surface. This prevents mud, snow, and road salt from getting permanently caked in, making post-drive rinses much easier. Just hit them with a pressure washer and the mud slides right off. They also help deflect gravel impacts.
Installation is straightforward. You just remove the factory felt liners and mount ours using the factory mounting points, meaning zero drilling or modifications to your truck.
If you want an easier setup, check them out here: https://bit.ly/c9xew
(Enjoy a 10% discount with code POWOQ10 for your first order!)
