powoq Wheel-Well Storage Box to Free Up Bed Space
powoq
🌟 Forum Vendor
Hey everyone,
When small essentials like straps and tools are left loose in the bed, they easily slide around while driving. Beyond the noise and potential scuffs, having scattered items across the bed floor breaks up your usable footprint, making it harder to pack larger gear.
To help address this without sacrificing the main cargo floor, we have a storage box designed to utilize the corner space over the passenger-side rear wheel well. It is compatible with 2019–2026 Chevrolet Silverado / GMC Sierra 1500. It does not fit 2019 LD/Classic models, trucks equipped with the CarbonPro bed, or Regular Cab with a long bed.
The organizer is constructed from carbon steel with a black powder-coated finish, providing good structural strength while resisting rust, corrosion, and daily wear from rough gear. Along the outer panels, integrated slotted cutouts provide attachment points for hanging accessories.
The unit bolts together from multiple panels, with gaps between the bottom plates that allow rainwater to drain freely. For mounting, it attaches directly using screws without drilling, keeping the setup straightforward.
If you're interested, you can find it here: Use code POWOQ10 at checkout to get 10% off your first order.
