Silverado ZR2 lift kit
By Putting a 4 inch lift on the Chevy Silverado ZR2 will it affect the multimatic shocks or anything on the truck?
The short answer, yes, it's going to affect the truck.
I don't know if there is a viable 4" lift on the market yet for the zr2 but the long answer will need to cover the need for new shocks, necessary front end parts, driving dynamics, etc.
A 4 inch lift package will pretty much remove everything ZR2 about the ZR2. (To do it correctly, and have proper extended length struts)
Will probably do okay selling the factory suspension off though.
So Monday I am having a 4 inch BDS lift put on my ZR two just came out. They bring a different shock mount, so you still get to use the same shocks.
Can you provide the part number for this lift kit? Everything I see if the the Colorado ZR2.
Looking forward to seeing it.
I'd like a 2 inch Cognito lift!
So it isnt even been advertised yet i went to toys for trucks they did a bunch of calling around and found it at bds Its supost to be done tomorrow ill let everyone know
Ok guys here it is 4” BDS lift 35x12.50 x20
Mickey tompson baja boss n fab nerf bars There was some cutting of plastic in the front rear wheel wells and alittle on the fron bumper but I couldn’t even tell all told it was a pretty penny
Looks awesome!
How’s it ride? Anything out of the normal on the install?
Looks pretty good. Can you run 37s?
I feel like mine needs another 2 inches to look good on these 295s that are 34.5 inches tall, but seems like a lot of space to fill for 4 inches of lift.
Fucking GM cannot get their wheel well geometry correct...... it's narrow front to back and too tall. Current 2500s same shit, but the 24s look like they may be better.
looks good
looks good
Nice set up
What leveling kit are you using. ?
So this is just a 4” spacer lift? Are both upper and lower control arms replaced? I’m guessing they utilize a 4” lifting block in the back?
