- Jan 1, 2023
- 3,808
- 8,089
Is this what you have? What drop height did you buy?Tongue weight on my Trailer is 1500# Dry lol. With my KRX loaded, Trailer level and nothing else it drops down to about 11-1200#. I set my trailer a little nose down and with everything else loaded I'm at about 1400#. My Trailer's GVWR is with 1500# tongue weight. My hitch is the new style Heavy. I got it right about the time they changed them. Actually had to wait a little bit for them to become available after I ordered. You don't hear the spring bars while driving. When you are pulling in and parking you can hear them some. Specially if you have the windows down and you are on uneven ground turning sharp. But just normal driving on the road you don't notice them at all. The APP is easy. Once everything is setup, each time you hook up you just enter your current tongue weight and the app tells you how much pressure you should add to the bars. Takes the guess work out. If nothing changes you don't have to change anything. If you need to add more or take some off the bars you just loosen one nut and turn that bolt in front of the ball. It's a pretty neat setup.
Heavy Duty Weight Distribution Hitch | Weigh Safe
Get the most reliable heavy-duty weight distribution hitch on the market. Designed for strength, precision, and safer towing performance.
